I got this error when trying to upgrade to DAQ 6.9 when using the Student
Version of LabView 6i. Note that the Student Version of LabView does not
support DAQ upgrades, I found this out the hard way. By the way, I'm a
fellow UW student, in the Physics Dept.
I had to remove all instances of LabView and DAQ to reinstall.
Jeff
"M. J. Eggertson" wrote in message
news:506500000008000000F6200000-991728092000@quiq.com...
> I'm trying to install LabView 6i on a W98SE system. The install has
> worked previously, but for some reason is now failing. I get the
> following error message from the Microsoft Installer:
> The feature you are trying to use is on a CD-ROM or other removable
> disk that is not available.
> Insert the " disk and clic
k OK.
> Seems simple enough, except for the proper disk is already in the
> CD-ROM. I'm assuming its looking for the .msi file, but when I point
> to it (lv60.msi) I get another error:
> The installation source for this product is not available. Verify that
> the source exists and that you can access it.
> Anyone know what's wrong? Its a little frustrating, especially since
> several successful installs have already been done.
> Michael J Eggertson
> Department of Chemistry
> University of Washington
> mje1@u.washington.edu
