08-15-2007 04:59 PM
Could somebody point me to way to fix this issue? Thanks very much,
Frank
08-15-2007 07:45 PM
New information:
I have tried the following samples VIs and all failed at the same vi as explained before (anvna Wait for Acquisition Complete.v) and all failed at the same place (please refer
to attached picture):
anvna Acquire Continuous Trace Example.vi
anvna Acquire Marker Data Example.vi
anvna Acquire Smith Plot Example.vi
anvna Acquire Trace Example.vi
The only VI that works is:
This VI does not call "anvna Wait for Acquisition Complete.vi" - Any thoughts?
Frank
08-16-2007 04:02 PM
Dennis Knutson or Altenbach -Do you have any thouhts as to why all 4 examples VIs for this equipment's library stop at "anvna Wait for Acquisition Complete"
Thanks very much,
Frank
08-17-2007 06:24 PM - edited 08-17-2007 06:24 PM
Hi Fvalenzu,
I have a few questions about your application.
Is the replacement instrument the same revision of the instrument you sent to get repaired?
Is the device at the same address?
Are you able to successfully communicate with the instrument in max using GPIB commands?
You might want to verify the program is calling the instrument by the correct alias or address and you are calling the device correctly. Also, I would check and see if there is a newer version of the IVI driver for your instrument. IVI drivers can be found at the link below.
ni.com/idnet
Regards
Message Edited by Andy L on 08-17-2007 06:25 PM
08-20-2007 12:12 PM
Andy,
I contacted Anritsu's tech support and upgraded this model to latest firmware and my labview code appears to be working fine. Therefore at this point it appears that everything is working fine. Thanks for your reply.
Frank
