08-17-2011 03:27 AM - edited 08-17-2011 03:36 AM
johnsold + 1
I have been guilty of it many times in the past, and I am sure I will do it again, so don't beat yourself up to much about it!!
Dom
08-18-2011 10:43 AM
Hi all. I'm back
I've studied my example, and corrected my mistakes. Finally I get Sum2 2D array.
Now I can clearly explain what I need to do for finishing my work.
I want to get graph of Sum2 regardless of Xm.(Finally I must receive 5 plots in one window: every column of sum2 regardless of Xm).
Can you help me with this?
Thank you so much in advance.
08-18-2011 10:44 AM
Here is my program.
08-18-2011 10:47 AM
Hey Moony,
I hate to say this but it doesn't really clear things up for me.
Build up a flow chart of how you expect your program to run.
It's hard, but it is very very very very good practice and will help you and others with debugging / program building.
Dom
08-18-2011 10:59 AM
In this case, please answer my last question.
Simply just say how can I use columns of 2D array. In other words, how can I split every column of the 2D array to the 1D array?
08-18-2011 11:10 AM
Index Array will let you get one column at a time. Just wire to the column index input. See the Help for more details.
Lynn
08-18-2011 12:00 PM
Thank you for your help and patience.
08-19-2011 03:23 AM
How are you getting on?
I have had another look at your latest program, getting the five graphs onto on chart is easy enough, I have done it in the attached program, but I am still not sure what you meant by the preceeding sentance:
"I want to get graph of Sum2 regardless of Xm"
Dom
08-19-2011 03:24 AM
It would help if I attached the vi!!!
08-19-2011 06:26 AM
Hi, Dominic.
Thank you so much for your post. I couldn't open your file, because my Labview version is 8.5.
Please, send me your file by saving for my version.
Thank you in advance.
