MAX unable to install XNET onto cRIO
I have a cRIO-9067 and a NI-9860 XNET module. I am trying to install NI-XNET onto the cRIO, but I am unable to. When I use MAX and use the Add/Remove Software Wizard, the option to check NI-XNET 19.1.0 is unavailable, stating that "it is not installed on your host", despite MAX reporting it installed on my PC. I have NI CompactRIO 19.1 installed as well. I am using LabView 2018 on Windows 7 Pro.
Before I used CompactRIO 19.1 I had 18.5 installed, so I installed XNET 18.5 and the same error occurred. I also fully removed the entire LabView stack from my PC and reinstalled it and no dice.
Is there a step I am missing here?
Gq1Of6P
Thanks!
Donney
(140 Views)
(87 Views)
Highlighted
Hi Oscar,
No I do not have that installed. How would I go about installing that?
Donney
(78 Views)
Accepted by topic author DonneyF
Donney, you should be able to select the option when installing the driver:
2019-10-09 16_44_34-Old XNET.pngNI-XNET 18 and previous
2019-10-09 16_44_34-New XNET.pngNI-XNET 19 and newer
If you do not see the option, make sure the Real-Time module is installed.
All the best,
(41 Views)
Thanks for the reply Oscar. The option did not appear when I tried to reinstall XNET via the Package Manger. I think it is because I had Real-Time 18.0 installed.
My solution was then to uninstall CompactRIO 19.1 and XNET 19.1 and manually download CompactRIO 18.5 and XNET 18.5 separately bypassing the Package Manager.
Now I am able to install XNET onto my cRIO.
Thanks for the help,
Donney
(31 Views)
