03-11-2011 02:03 PM
I have a PXI-8464 card, and it shows up on MAX, but it doesn't show up on my pull down manual in LabView. What is wrong?
In the LabView Project:
Thanks.
03-14-2011 03:17 PM
Good afternoon Bladhart,
I have had this happen to me several times. If you have not already tried it, select the Browse option on the drop-down menu (see Browse screenshot.png) and see if you can manually navigate to the device name that way.
In general, you can alter the devices shown in that drop-down menu by right-clicking on the menu and selecting I/O Name Filtering (see IO Name Filtering.png). On the menu that opens, you can make sure that the channel(s) and I/O type you are expecting is selected (see Filter Names.png).
Hope this helps! Good luck with your application.
~kgarrett
03-14-2011 06:48 PM
I think I have gone insane. Now, none of them are showing.
That blue block is the Pickering Visa initialization block. It was supposed to be PXI2::13::INSTR. I also have no browse button.
My filter also look different?
03-14-2011 07:02 PM
I have also just noticed that the instance of PXI-1042 under MY System doesn't show any of the devices.
03-15-2011 03:47 PM
The FPGA one doesn't show up either.
03-15-2011 05:44 PM
Hey Bladhart,
Sounds like you're just fallin' apart on me! Let's see if we can't get things working again. With this many modules, you should consider getting phone support-it would greatly expedite this process. I'll help you as much as I can through this forum, though! 🙂
Have you tried disconnecting and reconnecting the devices (you may have to close and re-open MAX before you can see them again)?
Since Pickering devices are not produced by National Instruments, I am not familiar with how they communicate with MAX. If you can tell me where you found the drivers for them, I can look into it further.
Also, what version of Real Time are you running?
cheers,
kgarrett
