08-21-2016 08:38 AM
@Bob: I repeat IMAQ dispose is not placed immediately after IMAQdx Get Image which you tried to explain. In the given example it is placed after three more fucntions:
IMAQdx Stop Acquisition, IMAQdx Unconfigure Acquistion, IMAQdx Close camera.
-If IMAQ dispose is right after IMAQdx Get Image, Yes there is race condition which is not the case in example.
@ richjoh Are you refering to my first post or the one which PalanivelT posted?
-If later is what you are refering i agree. But i am talking about my first post and i checked by highlight execution.
08-21-2016 12:34 PM
Uday,
First, I was commenting on Dr. Powell's subsequent note, which didn't use cameras. Second, even in the original example, the Principle of Data Flow says that technically (which is the way I was arguing), I'm still right. You could put a dozen functions in the sequence between the wire going to the Image Indicator and the Dispose sitting on the Error line, there would still not be any data dependence on the two functions.
From a "practical" standpoint, this shouldn't be a problem because the additional functions will probably cause a "time delay" before the Dispose fires, allowing the Image to be drawn, but there is nothing in the Block Diagram (without the Sequence) to ensure this. You brought this up as a "bad example", and took NI to task for not "fixing" it -- it may be "incomplete" and could probably be "improved" -- I encourage you to come up with a better (and technically correct) example, contact NI Software Support, and offer it to them.
08-21-2016 11:40 PM
08-22-2016 01:48 AM
udka wrote:-If you still want to display image in your indicator you can use snapshot mode in indicator which will make copy of image.Edit:The error wire has to pass from left to right through sequence structure.Same for Image wire.
Thanks for Info on snapshot mode,
Hope lot of disussion went on sequence strutcure,
just wanted to share my understanding,sequence structure doesnt play any difference betwen its presence and absence.
08-22-2016 04:15 AM - edited 08-22-2016 04:18 AM
@udka wrote:
-The IMAQ dispose is well placed after IMAQdx Stop acquisition, Unconfigure and Close camera vis.-If IMAQ dispose is immediately after Get image I completely agree with you that it can happen.-Where as when it is placed in the end I don't see any chance for it to dispose before displaying into indicator.
A race condition is where two operation need to execute in a defined order, but that order is not enforced. In many cases, timing delays will lead to the desired order, but this is a poor substitute for actually enforcing the order, for two reasons:
1) it is easy for someone at a later date to modify the code in such a way that time delays are no longer sufficient. For example, someone might not shutdown the camera because they want to continue using it, or they might place a subVI to modify the image before displaying it. If the image stops displaying, they will have difficulty identifying the source of the problem (race conditions are some of the worst bugs to diagnose). It's hard to appreciate in a simple example such as this, but this issue becomes more serious in real-world complex code.
2) Even if you "don't see a chance" there is always a chance, at least on non-RT operating systems like Windows (where threads can be delayed for many milliseconds), and especially when one of the "racing" operations is in the UI thread (like the displaying of image in this example). The single UI thread is shared, and long UI operations in one part of the code can cause long delays elsewhere.
As a result, it is always better for it to be "clearly impossible" for something to execute out of order, rather than for one to "not see a chance" of it happening.
