Reply
Lottery Generator
Re: Lottery Generator
I meant using the rifle VI from the palette. Smiley Wink
LabVIEW Champion Do more with less code and in less time
Message 21 of 24
(174 Views)
Wow. Some amazing insights in here.
Can I ask why the scale by power of two is used rather than multiply?
Message 22 of 24
(149 Views)
I will wait to hear from Christian and learn as well but I can observe that a scale by a power of two in binary is simply an arithmetic shift left.
Ben
Message 23 of 24
(141 Views)
Multiply is probably a better choice here, because the price can change by a random amount. A multiplication/division by integer powers of two corresponds to an arithmetic shift (not logical shift, important difference when the input is negative) for integers. Even for floating point numbers, only a subset of bits need to be touched, but I doubt it would make a difference on a modern processor (but would be of great help when using paper& pencil Smiley Happy).
So, yes we should use multiplication here. Shifts/powers of two should be used where it is more natural, e.g. if you would implement the cooley-tuckey fft or a binary search. Sorry about that.
Message 24 of 24
(133 Views)
