08-24-2011 01:34 PM
I am trying to open a vi that was obviously created in 8.5, then upgraded to 8.6. I am now being peppered with 100's of cannot find the llb errors, which for every single one I have to find the correct file, then select the function from the llb.
Is this really the way this error should be handled? I have specified the location of IMAQ Rectangle 3 times now and it has become a little silly that this file cannot load correctly.
Thanks for your help
08-25-2011 09:20 AM
If you have VIs created under LV 8.5 using libraries from the Vision Development Module 8.5,
and you load them with LV 8.6 now, you will also have to Vision Development Module 8.6 installed!
Christian
