Long time to set up a TCP connection with CompactRIO
I have made a very simple program on a CompactRIO (NI cRIO-9002) device that just listens on a port for a connection and when a connection is established, it sends a text string, closes the connection and starts waiting for a new connection again. I tested this program first on a local area network and it worked fine. The response seemed to be almost instantaneous. I then hocked the unit up on an external network with a static IP address. Now, the same program used more than 10 seconds to respond!
Any ideas what it could be?
Terje
(2,601 Views)
It turned out that the DNS address that I had specified was wrong. After correcting that the response time was good.
(2,585 Views)
