Long term countdown timer
@ BowenM
Sir i wanna ask why did u minus the current time with the check out time you added yourself.
I will be grateful to know more about what u show me, i will make sure i can implement it in my
own VI
Message 21 of 33
(342 Views)
Highlighted
Zahkay-
You have two variables 'check out time' and 'current time'- both in seconds. Tell me, how would you calculate the time the item has been checked out in seconds? Not in LabVIEW, just in words?
Message 22 of 33
(333 Views)
Because current time-check out time>7 is the condition. Basic arithmetic and logic.
And please note that you are neither using a database or excel. You have a text file and using the correct terms is important. An actual database would allow you to make a simple query.
Message 23 of 33
(331 Views)
The current time is the time of the computer which i put in my VI.
for the check out i would have take the total second of all the 7 days
sir
is it okie
Message 24 of 33
(327 Views)
It's okay as long as you do the math and comparison correctly.
Message 25 of 33
(324 Views)
ohh yeah. u r right . simple logic.
i am sorry for asking this kind of ques. Actually i was trying lots n lots that at the end i confuse myself
but i wanted to ask , but in the VI, the check out time is constant.
i have to manually insert for all for the constant check out time.
Message 26 of 33
(320 Views)
actually sorry for this term database
to make it more clearer,
i am trying to monitor the laboratory equipment in and out by student.
actually when i am putting the output in the concatenate string,
there is an error.
Message 27 of 33
(318 Views)
And you've been told the cause and the fix for the error. What didn't you understand?
Message 28 of 33
(306 Views)
Yeah for the error, i can solve it.
But in the vi, the check out date was constant which is assigned by the user.
This is my issue.
the check out data , i dont know when it is.( i donr want it to be constant)
i hope , i am clear now
Message 29 of 33
(279 Views)
When people give you an example of code that is a constant, it is to show you what the calculations would be.  Obviously, in a real app, it wouldn't be a constant.  It is up to you as the programmer to replace it with whatever input works in your application.  You need to start thinking for yourself at some point of time since it is YOUR project.
Message 30 of 33
(270 Views)
