05-22-2018 09:38 AM
Hello everyone,
I am currently in an internship about frequency modulation spectroscopy. I would like to have a lock-in detection on labview. The objectiv is to obtain signals 1f and 2f simultaneously in a simple manner. I'am a beginner on labview and the internship is relatively short... Can someone help me ?
Thank you in advance for your answer.
Nicolas
05-23-2018 10:52 AM
Hi Colapili,
I guess it will probably depend on the hardware you are using. But I could find some examples on the links below :
If you are using DAQ devices :
https://forums.ni.com/t5/Dynamic-Signal-Acquisition/Lock-in-Amplifier-and-DAQmx/td-p/282419
If you are using myRIO :
http://sine.ni.com/nips/cds/view/p/lang/en/nid/212768
If you are using FPGA :
https://forums.ni.com/t5/Example-Programs/Lock-in-Amplifier-on-LabVIEW-FPGA/ta-p/3500412
I hope it helps!
M-junior
