09-08-2011 12:17 PM
Is it possible to know the locations of control and indicator on the pallettes from a pre-designed vi?
Thx
09-08-2011 12:20 PM
I'm not clear on what you are asking.
What "pre-designed VI" are you talking about?
How does that have anything to do with the palettes?
If you can explain your question better, perhaps even tell for what purpose you are asking, we might be able to help answer your question.
09-08-2011 12:40 PM
If you are asking "Given a control on the front panel of an existing VI, how do I find the palette it was originally found in?"
Then, no there is no direct way.
If the controls have been customized then there is no palette.
Ben
