Locate a SubVI in messy State Machine
Hi there,
I inherited a rather large state machine with an enormous number of states and SubVIs. It would help a lot, if there where a function in Labview to find the exact location(s) of a SubVi in the block diagram. Is there such a function in Labview?
Thanks for your help!
(3,514 Views)
Accepted by topic author hering
You can use the Find tool (Ctrl + F) on the calling block diagram and search for object => VI.
EDIT: You can find the caller(s) of a specific subVI in your project by right clicking it in the project item view and select Find => Callers.
Alternatively, open the VI Hierarchy (View), look for your VI you are searching, right click it and select "Find All Instances".
Norbert
Expert: Geometry
(3,497 Views)
Thanks Norbert. That is exactly what I was looking for!
(3,487 Views)
