06-25-2018 01:55 AM
Hi
We have a use case where we have to load a LabVIEW Built Application(EXE) in VI Front Panel. Can anyone suggest how to do the same in LabVIEW?
06-25-2018 10:36 AM
While I have never done so I would suspect you have to make sure VI server is enabled fore the exe and the target VI is exported.
Look under the project settings to enable the VI serve and set the port of same.
There are also two ini tokens needed in the exe startup to enable VI serve in the ini.
They are not included after running the build ( do not ask me why!).
server.tcp.enabled=True
server.tcp.port=3364
Ben
