05-15-2023 03:25 PM
Hello everyone,
I am working on a 40-channel signal acquisition and real-time display LabVIEW program.
I am having difficulty loading configuration files (saving files is fine).
Specifically, having the config file load will cause plt_info to be set correctly (see images below in order of before > during > after), but once the "Ok" dialog box is pressed, plt_info will be reset to its previous state, where I need it to be set to its "during" state.
I am unable to post the full project, just the subVI.
I've been working on this error for at least 4 weeks - I feel like I've tried everything.
Thank you in advance!
05-16-2023 07:21 AM
Sorry, I'm stuck at LabVIEW 2021.
05-16-2023 11:33 AM
since we cannot see what happens inside the "subVI_ConfigFile.vi" we can make no statement to your problem.
