Load VI Ref into Subpanel massive lag with CrowdStrike
Our test sequencer loads about 1000 VI refs into our main subpanel and runs them.
One specific VI causes LabVIEW to lag for at least one minute, but only when calling it for the second time (meaning it is already loaded from disk and the VI ref is reused)
Other parts of the application like a loop that sends data to IT also lags, executes every 30 seconds instead of every 5.
This happens since the installation of CrowdStrike Falcon Sensor.
Anyone have similar issues with CrowdStrike?
(547 Views)
My company doesn't use CrowdStrike.  I believe they were considering it until the big outage back in 2024, then they backed off.
Regardless, whether it's CrowdStrike specifically or any other anti-virus or other threat protection method, you basically have 2 options when you get problems with it but can't remove it.
Option 1: Exclusions.  Convince whoever is managing it for your company that the performance hit is severe enough that they need to exclude LabVIEW files or processes from it.
Option 2: Workarounds.  Try to narrow down exactly what causes the biggest lags, and see if you can either do less of that, do something else that doesn't require as much action by the scanning process, or see if you can at least "batch up" the problem.  By batching up, that means if the problem is "per file", see if you can merge them all together into one file (.llb, .lvlibp, .zip, etc...).  Or if it's something that "sends data" but doesn't need any data back in response, create a separate process that sends that data so your main process isn't held up by it, and the separate process perhaps sends the data every minute instead of every 5 seconds, or whatever.
(490 Views)
If it's the 2nd run it shouldn't be AV, maybe the original ref/program isn't shut down and you get into some timeout situation?
Qestit Systems
Certified-LabVIEW-Developer
(454 Views)
