Load Jpeg and convert to 8 bit grayscale array?
Hi muks,
what do you mean?
Mike
Message 11 of 23
(4,886 Views)
Mike,
          Extracting the luminance plane for example from a jpeg image should convert it into a gray scale 8 bit image right?
Message 12 of 23
(4,858 Views)
Hi muks,
i don´t understand what you want to tell me. Can you explain please?
Mike
Message Edited by MikeS81 on 07-25-2008 08:22 AM
Message 13 of 23
(4,854 Views)
Hi Chris,
to convert a RGB value to a grayscale value use this formula: "gray = 0.299R+0.587G+0.114B". To detect your edge see something like "Sobel-Operator", "Prewitt-Operator", or .... .
Mike
I was just  saying that extracting a  single plane from a n RGB image should convert it into  a gray scale image.
Message 14 of 23
(4,845 Views)
Hello Mike, thank you very much for the quick response. I tried the code and it does not work for me. The truth is that my problem is other, but I thought it could be the solution.
Although my problem is this: I've created a matrix of 640x480 floating point and I need it to show it in grey scale.  I found an example from NI where a palette of gray is created and used with Flatten Pixmap box, but this example use the function Join which is it not available in the 7.1 version, this is the one that I work with.  If anyone knows how to solve this problem, I'll really appreciate it.
Anfego
Message 15 of 23
(4,826 Views)
Hi Anfego,
which example do you mean? Can you show it please?
Mike
Message 16 of 23
(4,816 Views)
Did you try  array  to  image function ? can you post your  array?
Message 17 of 23
(4,810 Views)
Hi, those are example what Im talking about.
Message 18 of 23
(4,791 Views)
Hi Anfego,
see the attached example please.
Hope it helps.
Mike
Message 19 of 23
(4,784 Views)
Thank you so much, Mike, it is perfect.
Cheer!!! XD
Message 20 of 23
(4,759 Views)
