I have done something similar, except I used the tick symbol to indicate that the item has been selected and used '0 or 1' selection mode.
The steps would be:
- check if the listbox value - if the value has changes or >-1 and there is no tick there then put a tick - if the value has changes or >-1 and there is a tick there then put remove the tick
I hope this alternative helps
Tim
Luis Diaz wrote:
> Dear Sir or Madam, > > I would appreciate any comment or suggestion on the following question. > > How I can limit the number of items selected in a ListBox? > > Assume that you have 3 items but I want to have 1 or 2 selected items > but no more. > > The selection mode: (0 or more) or (1 or more) does not work for me in > this case. > > Thanks in advance for your Help. > > Luis Diaz-Ballote. > luis_diaz_ballote@hotmail.com
