Reply
List Data Set Runs.vi and memory
Highlighted
Hello.
I use DataSet Marking IO to save variabkes of value. I save it easy.
Then I have vi, where is shown saved values. To take saved value from Citadel Database I use List Data Set Runs.vi. When I open this vi, my memory usage is grown up from 80 000 kb to 142 000 kb. And there are apeear window with eror about memory usage. (When I test this vi without function  List Data Set Runs.vi there was not any increase of memory). Can somebody help me to solve this problem? I also try to use request deallocation function, but there was not any effect.
(351 Views)
There is error like:
"The top-level VI "Test.vi" was stopped at unknown on rhe block diagram of "ERR_MergeErrors.vi" "
(339 Views)
Hi RuslRusl,
Could you post a screenshot of the error you're seeing and/or the VI in which it occurs? That would be a big help.
(320 Views)
I can`t find this vi, because all vi`s in DSC module is blocked. So I can`t see block diagram of vi.
I`ll post screenshot, when the error appear again.
(315 Views)
