Linux LabVIEW 8.2, playing looped .wav
Hi Coq rouge,
No worries, I sometimes feel like I don't know any LabVIEW Smiley Sad.
Since I don't have my 8.2 CD on me I can't test if a newer version of the OS would do the trick – something on the to-do list when I am back here.
We did think of a cute work around: use the command line to play the sound file which means we only need to use the System Exec.vi. Works fine on my end.
Thanks for the suggestions and I will post back once I have installed 8.2 on a newer version to see if that solves it (will be mid-July though).
Sincerely,
Bertrand
Message 11 of 13
(448 Views)
hi
Thank you coq rouge for telling me how to save vi in previous version.
@VI monkey
I saved that vi in 8.2 version. check if it is working now or not. As i dont have much experience like you guys, i dont have knowledge of driver problems as i have never faced it yet. Tell me if i can help you in any other way.
Best luck
Gaurav kSmiley Happy
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
Message 12 of 13
(444 Views)
Hi Gaurav kSmiley Happy,
Thanks for saving it in 8.2. The result is the same though, it still hangs on the second iteration.
What version of Linux are you running?
Bertrand
Message 13 of 13
(431 Views)
