06-03-2009 04:10 PM
Hi Coq rouge,
No worries, I sometimes feel like I don't know any LabVIEW .
Since I don't have my 8.2 CD on me I can't test if a newer version of the OS would do the trick – something on the to-do list when I am back here.
We did think of a cute work around: use the command line to play the sound file which means we only need to use the System Exec.vi. Works fine on my end.
Thanks for the suggestions and I will post back once I have installed 8.2 on a newer version to see if that solves it (will be mid-July though).
Sincerely,
Bertrand
06-03-2009 09:43 PM
hi
Thank you coq rouge for telling me how to save vi in previous version.
@VI monkey
I saved that vi in 8.2 version. check if it is working now or not. As i dont have much experience like you guys, i dont have knowledge of driver problems as i have never faced it yet. Tell me if i can help you in any other way.
Best luck
Gaurav k
06-04-2009 10:13 AM
Hi Gaurav k,
Thanks for saving it in 8.2. The result is the same though, it still hangs on the second iteration.
What version of Linux are you running?
Bertrand
