06-02-2009 08:57 PM
Dear NI Forum,
I am running LabVIEW 8.2 on Linux (Scientific Linux 4.5, 2.6.9-78.0.13) and am trying to get a .wav sound file played repeatedly. I followed the example in the LabVIEW help, but it only plays once (see attachment) - the text stated it will "continually play a sound file". Hopefully it is an easy oversight on my part on how this is done.
Bertrand
06-02-2009 11:13 PM
hi,
see your modified vi.
Best luck
Gaurav k
don't forget Kudos for good answer
06-02-2009 11:34 PM
Thanks. It plays once, but then hangs on the 'Play Sound File.vi" during the next iteration. I need to kill LabVIEW in order to stop the VI. I noticed the VI you attached was done in 8.5, could you check in 8.2 if you can re-produce the error?
Bertrand
06-02-2009 11:58 PM
hi
I dont have labview 8.2, but in labview 8.5 that example is working fine for me.
wait i ll try different solution and will get back 2 u
Gaurav k
06-03-2009 12:17 AM
hi
Try this. i have done slight change in the code. i hope it will work for you
Best luck
Gaurav k
06-03-2009 09:44 AM
Hi Gaurav,
Sorry for the delay - on the East coast of the US.
The VI still hangs on the second iteration. I traced it to the "Call Library Function" in the Play Sound File.vi. Any thoughts on this? Too bad I don't have my 8.5 installers with me.
Thanks for the help,
Bertrand
06-03-2009 11:42 AM
Hi
Labview is shipped with a lot of examples. Also sound. Have you tried help->Find examples. Also if you are new to Labview always enable content help. And use the detailed help option, then in doubt. From this I found this note "You must have the Open Sound System (OSS) driver to use this VI" if your system hangs it could be something with this driver. Since I do not think a 8.5 VI can be opened in 8.2. But have tried to recompile the VI from Gaurav?
@Gaurav
You can use save for previous version for saving VIs in say 8.2
06-03-2009 11:45 AM
06-03-2009 02:38 PM
Hi Coq rouge,
The first thing I did was look at the examples provided by NI – been programming in LabVIEW for ten years now 🙂 The funny thing is as I had posted initially the "playing sound continually" example doesn't work the way it is advertised – nor do I see it ever working, given that the "Play sound file" VI is outside of the while loop.
I will look into the OSS driver – new to Linux so it might take a bit of googling around (best way to learn).
I actually opened up the 8.5 VI on my Mac and then manually recreated it in 8.2 on Linux. One thing I noticed is the sound VI's are different from Mac and Linux. On my Mac I only need a single VI to play the file and to loop it I just have it in a while loop.
Tried the -1 for the timeout and I got the same result of hanging on the second iteration.
Thanks for the suggestion, I hope there is a solution to it other than upgrading to 8.5 or using a different Linux flavor.
Bertrand
06-03-2009 03:21 PM
Sorry I did not know you have 10 years of experience. But I know the Labview sound driver in windows very well. The input part is very good but the output part stinks like a skunk if you want to use it as a continuous glitch free waveform generator. But anyway this problems should have nothing to do with your problem. I tested the latest suggestion from Gaurav. I works and by setting the timeout to -1 the "Sound play" VI will not end before the sound is played. So I think the OSS might be the problem. But well my Linux knowledge will not cover even my smallest fingernail so I shall not be cocky. Even if my nick is Coq Rouge 😉
