12-13-2013 05:53 AM
Hello! I'm totally new to this great software and the truth is I'm lost 😧
I try to explain in more detail what I have to do, I hope you can help me please it's urgent T_T
I must make 3 tables should be linked to each other , ie a table where the name of a user will be manually enter, another where you manually enter the last name of a user and the third which will automatically enter the power of each user (for the automatic entry i will use a random data ) . Each table will have a box number , for example :
Table 1, Box 1: Paul
Table 2, Box 1: Gate
Table 3, Box 1: 3.74
Table 1, Box 2: Miguel
Table 2, Box 2: Ramos
Table 3, Box 2: 4.99
Table 1, Box 3: Maelle
Table 2, Box 3: Branco
Table 3, Box 3 : 4.98
I mean, I link the box to a table with the other three . And given that the program must compare the data in Table 3 (power ) and display data from the best user ( who has the highest power). In this example, the program should display :
BEST USER :
POWER: 4.99
(Is not nessesary save the information when i will close the program)
I do not know if I 'm asking a lot , I have a very clear idea in my head of what I have to do , but being a new software for my not know how to implement it .
Thank you in advance for your help and quick and ilustrative response! xD
Solved! Go to Solution.
12-13-2013 06:05 AM
12-13-2013 06:15 AM
I dont know even how to start 😧 i can just make the tables and make the "random data" in table 3...
12-13-2013 06:37 AM
Did tried something with basic understanding of your question check if this is what you need??
-Still not clear what you mean by table??( In my opinion table is 2d array of values here if not please let me know.)
-That's the reason i asked you to show your code what you have done then it will be more clear.
12-15-2013 09:40 AM
Thank you for you reply!
I saw that you registered the program and is only 1 part of what I wanted, I attached a picture to this message with a draw to give to clearly understand my idea.
Thank you very much for your support!
12-15-2013 11:38 AM
12-15-2013 12:22 PM - edited 12-15-2013 12:33 PM
Hi Miguel_Exe
-Please check the snippet it does exactly what you said.
-The Box 1,2,3 you mentioned are array indices.For example if you use table_1 and index it with 0(Yes, arrays index starts from 0), you will get first element which is Miguel-Vi used is Index Array.
-For linking you can use string concatenation. Get each element from array using proper index and use Concatenate Strings.
-I am getting the last Numerical Table and passing it to Array Max and Min to get where maximum value is and using same index (Box value) am getting full name.
12-16-2013 01:57 AM
12-16-2013 02:22 AM
12-16-2013 08:10 AM
Hi udka,
strings are sorted lexically, while numbers are sorted by their value.
Which string is bigger: "222" or "39"? Which number is bigger: 39 or 222?
Also using strings will go insane when the user hits the wrong keys: what happens when the user inputs "123-23" instead of "123.23"?
