Limit opening TCP/IP connections
Hi all,
I am writing an application to communicate with an instrument via TCP/IP.  Because of details regarding how the instruments program is written, it is best that I open and close the socket for each data exchange.  The instrument is using a single board computer running a Linux OS.  The problem that I am having is that I can only open and close the socket connection 3962 times.  On the next attempt I get the following message:
Error 60 occurred at TCP Open Connection in Untitled 1
Possible reason(s):
LabVIEW:  The specified network address is currently in use.
Any idea as to what might this message really means, and how I might avoid it?
Thanks for any assistance,
Jim
Jim
LV 2020
(3,499 Views)
I'm guessing it's a LINUX configuration issue. I did a couple of quick searches, and found this discussion.  It sounds most like your problem...
http://mail-archive.objectweb.org/director/2000-07/msg00018.html
Original Google search was "TCP LINUX 3960 connections"
(3,492 Views)
Phillip,
Thank you, I believe that you have hit the nail on the head.  I neglected to place Linux in my search parameters.  Now our developer believes my statement that the problem is in the box, not my code!
Jim
Jim
LV 2020
(3,487 Views)
You're welcome!
(3,483 Views)
