Legend for a 3D Surface Plot
"save it as a Labview 7.1 file"
Ben
Message 11 of 17
(2,556 Views)
Thank you.
I like the color scale very much. Can you please save it as a Labview 7.1 file?
Patrick
Message 12 of 17
(2,453 Views)
See reply 9.
The code is attached as LV 7.1
Ben
Message 13 of 17
(2,438 Views)
But I get the following error, when I'm opening the file.
Error loading control. A newer version needed. The default values for the settings will be used.
And then there only appears a red frame, were the figure is normally placed.
Message 14 of 17
(2,406 Views)
Try down loading it to your machine before you try to open it.
And if all else fails you could code it up yourself, I did post images of the code.
Ben
Message 15 of 17
(2,403 Views)
I will have to code it on my own.
Nether the less: Thank you.
Message 16 of 17
(2,399 Views)
I took Ben's example and modified it to fit my application more.  I made it cleaner and more interactive.  Just thought I'd share with you guys.
Tim Elsey
Certified LabVIEW Architect
Message 17 of 17
(1,471 Views)
