11-05-2018 02:33 PM
Hello everyone, i have the following setup, on one computer i have a tone generator Vi, that generates tones in differents waveforms and frequencies, and on the other computer i have this sound examine Vi, i connect them via AUX, in generator i plug in the headphones jack and in the sound examine i plug in the microphone jack, everything works great, the waveforms are clear and all, but im getting on the graph both the left and right audio channel, is there a way to get the left and right audio channels from two different sources, mostly because i want to use a summator and do some modulation, the source of the information is from the microphone.
Here is my Vi.
Solved! Go to Solution.
11-06-2018 04:25 AM
Your answer is in the express VI.
If you do it manually, you will be able to separate them easily.
You also can use index array to separate them. 😉
Benoit
11-06-2018 04:30 AM
Thank you, i toltaly forgot that i can array index the stereo input, it worked!
