Led RGB connected to MyRIO
Hello everyone!
I don't have electronic skills and I need to connect a RGB strip Led to MyRIO for a project.
I'd like to know which MyRIO pin I should use in order to connect RGB cable to MyRIO.
Thanks for helping!
(5,877 Views)
What type of LED strip do you have? Is it something based on the WS2081? I used some of these RGB LED strips in my Giant Tetris, I have posted about it here and there's even some sample code for the myRIO: https://decibel.ni.com/content/docs/DOC-35435
(blog)
(5,825 Views)
Thanks for your answer! By the way I should use this type of led but I don't know how to connect RGB cables to MyRIO pins. rgb led.JPG
MyRIO project essentials guide only explanes  how to connect a single discrete led to MyRIO (like this:discrte led.JPG) but not how to connect a strip led with four cables!
Do you have any suggestion?!
Thanks again!
(5,816 Views)
Did you actually read the link I posted? All of the answers you need are in there (under the hardware section - wiring, power requirements, converting the 3.3V to 5V). If you have any specific questions, then let me know.
(blog)
(5,808 Views)
ok..now I get it!! I hadn' t read that part quite accurately!
Thank you so much for your help!
(5,801 Views)
