Large Data handling and Report generation
I guess the Excel sheet you attached is a normal .csv file format. In that case you can use the Read from spreadsheet file by specifying the data offset and decimate them so you will have only the required values in memory that you can easily plot it. At the same time in a for loop you can append the data to the Report and finally take the Image of the plot and update that to the report.
Message 11 of 17
(1,387 Views)
thanks for the suggestion!
the question is how can i combine / apend 30 worksheets in one excel file? Is there a similar example available?
Message 12 of 17
(1,370 Views)
I tried to find the example to combine the excel files.
I modified the file as per my requirement.
IF I want to combine these two excel files in one file.
I am still not able to do.
What is the reason?
Message 13 of 17
(1,358 Views)
I am getting error.
I simply want two excel files be combined in one file automatically.
Message 14 of 17
(1,344 Views)
I ran across the following KnowledgeBase article and thought it might be helpful.  It gives the procedure for appending to an excel file.
http://digital.ni.com/public.nsf/allkb/EFCE1C25DCE7483E86256CAF00539451?OpenDocument
Dave C.
Message 15 of 17
(1,330 Views)
Thank you for all your suggestions and comments! I could make the report generation program well.
If you have do let me kow how to beautify the report with labview report generation kit?
Message 16 of 17
(1,317 Views)
I see you are in this issue for a long time and its good that you got a solution. Beutify the report? 🙂
Message 17 of 17
(1,313 Views)
