LaqbVIEW 7.1.1 does not find a specific breakpoint, but stops execution there
In your front panel why is the "Start FG" button always pressed?Is that what u expect?
Message 11 of 22
(1,808 Views)
Muks,
you made my day. Replacing the flat sequence with a stacked one and vice versa solved that problem. Maybe it was an internal flaw in LV 7.11? Shall I update? I'll re-think it, especially as the brand-new 8.6 DVDs came in today...
Greetings from Germany!
Uwe
Message 12 of 22
(1,806 Views)
But as you can see when i replaced the flat sequence the break point seems to have got cleared.Even I am not quiet sure why that red rectangle was encapsulating ur flat sequence.May be some one can throw some light on it. Does replacing the flat sequece help?
Message 13 of 22
(1,806 Views)
Thats a flaw in my code. But its unimportant, as I use the 'Mouse-up' event in order to continue. Simply a copied code snipped...
Uwe
Message 14 of 22
(1,803 Views)
So the code is waiting for the event. Are you still stuck?
Message 15 of 22
(1,801 Views)
Muks,
Glad  to help.But do share what was causing the problem if you had figured that out .Might come handy for  someone.
Message 16 of 22
(1,799 Views)
Hi Lul,
When i removed the breakpoint i also had a refresh problem.  I had to minimise then maximise the screen in order for it to update the diagram.  I have found LabVIEW does this from time to time and worth keeping an eye out for.
Craig
LabVIEW 2012
Message 17 of 22
(1,774 Views)
Hi craig,
             Thanx for chipping in with your ideas. I tried that too but still that red rectangle all swallowing up the sequences. I faintly remember encountering it before but dont remember the fix.
Message 18 of 22
(1,760 Views)
again thanx to all who helped. I have solved that issue by changing the flat sequence into a stacked one. This removed that 'effective breakpoint', if I can tell it such. In order to have code easier to read and document I switched back to a flat sequence.
 Again, this is still LV7.11, allthough I have every newer version including 86 as arrived today. /.11 has the nice feature to be able to install a FD version onto a private account on a productive machne for debugging purposes. I don't have all the required devices on my workhorse PC...
I'll update this thread if I get any response from NI on the cause of that 'feature'.
Uwe
Message 19 of 22
(1,753 Views)
I suspect that ther was some corruption in your VI, because if I do a search for "breakpoints" in LabVIEW 8.5.1, it does not find any. 😮
However, the "edit...remove breakpoints from hierarchy" removes it just fine. Unfortunately, this was not available in 7.1 if I remember correctly
New in 8.6 is the breakpoint manager and it can easily be used to clear that breakpoint. Time to upgrade. 😄
Message 20 of 22
(1,732 Views)
