07-22-2019 02:05 PM
I currently have a computer connected to my chassis but the computer is a windows 7. However, I have tasks I want to perform on a separate laptop instead. Is there a way to run LabVIEW on both the computer and laptop with same hardware?
I'm not sure I worded that appropriately.
Thanks in advance
07-22-2019 02:53 PM
Can you elaborate on the setup? From what I am reading it seems as though you want to connect 2 computers at the same time to the same DAQ?
07-22-2019 03:04 PM
Essentially yes.
The computer in question is built into the chassis. So, the chassis acts as it's CPU.
Now, I want to connect the laptop.
07-22-2019 03:31 PM - edited 07-22-2019 03:31 PM
When I use a PCIe, I access it with the computer that is hooked up to and communicate to it directly, there is no way to have a laptop be able to access it physically. Can you physically connect the PCIe with the laptop after it is installed in the chassis? Also, why do you need a second computer, can you not use the first? Sorry for so many questions, still trying to figure up your setup and see what you are trying to accomplish and the best way to do so.
07-23-2019 08:32 AM
It sounds like you have a PXI system with a Controller running Windows 7, and accessing the hardware plugged into the PXI chassis through DAQmx.
Another (better?) way to use a PXI system is to run a Real-Time OS on its Controller, either PharLap or Real-Time Linux (my PXIs are fairly old, so I run PharLap). When running in this RT mode, the entire PXI Chassis becomes the Remote Target for a Host PC system connected to it via a TCP/IP connection (often through a second NIC on the Host machine, connected through a direct connection for optimum data transfers).
If you want your PXIe Controller to run both as a Host and as an RT Remote, you can do that by setting up dual-booting on its Hard Drive. This can be tricky to set up -- I've always avoided it, myself, choosing to use the PXI as a LabVIEW RT Target only. You can find more information such as this by searching the Web (try "Dual boot PXI").
07-24-2019 08:55 AM
Could you please further explain how to run a real time OS on the controller, I'm having a hard time following
07-24-2019 11:22 AM
07-24-2019 01:15 PM
What is the Controller you are using? it would be the wide module in the first Slot. I believe the link Gregory provided shows how you install Linux RT on certain Controllers. I haven't worked with "modern" PXI systems (mine is more than a decade old), but generally the Controllers ran either Windows (and not an RT-OS) or Real-Time -- to get them to run both required some "Partition Magic" to create a dual-boot system (which has its own problems and peculiarities.
07-24-2019 01:20 PM - edited 07-24-2019 01:21 PM
PXIe-8821
07-24-2019 01:40 PM
So the controller currently runs windows on a PC, and it's an embedded controller. What I'm trying to do is run LabVIEW on a separate laptop using the DAQ card connected to this chassis.
Is this possible?
