Labview2017 will disable my wifi connection
I missed this thread since I do not have LV17 installed on my laptop, but I have been experiencing these issues for years.  Since it was built for Win10 and I shoe-horned Windows7 onto it, I was quick to blame Windows or Intel for the issues.
At first it was mostly an annoyance, reconnecting to Wi-Fi after a sleep would sometimes fail, and at best take a long time.  Then it progressed and I usually had to disable and then re-enable the wi-fi adapter after sleep.
Then I installed the most recent myRIO toolkit, and immediately the problem became worse, and untenable.  After sleep, the Wi-Fi adapter shows an error in Device Manager, disabling and enabling no longer fixes it.  Nothing fixes it except a reboot.  Collateral damage is my NVIDIA 3D adapter which also gets broken after a sleep cycle.
I'll see if I can narrow down the culprit, pretty clear that it is related to the NI software I installed since I can restore from before and after backups and see the problem appear and disappear.
Message 31 of 41
(2,251 Views)
Hi, after strictly NIDAQmx only installation (no LabVIEW or anything else) there are 8 NI services (see attached picture). You can easily count number of combinations I need to proceed (disable one service, turn laptop off, turn it on, go to sleep mode, wake-up it, check wifi). I am really sorry, but NOOO, this has to be done by NI guys.
This issue costs me several days already and is better for me to downgrade to LabVIEW 2016 and to old DAQ from 2016 where are no such troubles. Pitty nobody at NI takes care about this since it is complained so many months already by many people in this thread and also here (they claim it is solved HA!): https://forums.ni.com/t5/LabVIEW/Labview2017-will-disable-my-wifi-connection/m-p/3956515/highlight/f....
After very detailed description this week NI support asked me how much it bothers me. Sad. Are you serious NI support? Am I alone who is struggling with this?
Petr
Message 32 of 41
(2,231 Views)
If NI reads this, "It bothers us a LOT!"  I had to acquire another laptop for normal use.  You can NO LONGER use the sleep function on the laptop.  You must completely shut it down every time you leave it.  Really not acceptable.   This is a significant flaw you should look into, in my humble opinion.
As an aside, I tried disabling some of the NI functions, but never found the right one to correct this problem.  Sorry I did not keep a list of the ones I disabled.  At the time I was thinking it was a Windows 10 or WiFi card driver problem... now we know for 100% certainty it is a NI induced problem.
Message 33 of 41
(2,200 Views)
Hope nobody feel I do spamm the thread. I have been working constructively with the support people again and again. You better don't ask me about total number of hours already spent on this issue with the support people and mostly on myself... No I don't like the idea to have 2 laptops for my everyday job: one for NI SW with no chance to use WiFi after sleep mode and another lapotop for the rest of SW. Too expensive, too uncomfortable.
What I investigated today can be seen on the attached figure. Could other people suffering with the same issue try to disable following services and report here the status with WiFi?
-NI PXI Chassis Management Service
-NI PXI Resource Manager
Please note: there is strictly NI DAQmx only (really nothing else from NI) installed on my laptop to isolate as much as possible the source of troubles, what is by my opinion NI DAQmx.
Petr
Message 34 of 41
(2,176 Views)
Not sure but I would think that the Chassis Management Service is probably not the problem (you don't show a column where this was enabled and the PXI Resource Manager was not and it may not be possible to have it enabled without the PXI Resource Manager) but I definitely would expect the PXI Resource Manager to be the primary suspect.
PXI is for the most part a different mechanical implementation of the PCI bus specification with additional hardware. The NI PXI Resource Manager has to interface on a very low level to the Windows device management in order to perform its services and despite its name it is also used by NI for the management of PCI hardware resources for their PCI and PCIe cards. It's a feasible assumption that the problem lays in here. It could be a power management event that is not correctly forwarded through the driver stack or it could be a specific issue in one of the chipset drivers that makes itself apparent when the NI PXI Resource Manager is hooking itself into the driver stack.
This kind of feedback is definitely the productive kind as it pinpoints the problem to a specific software component. Now NI will need to reproduce this with a hardware setup that is the same as your computer so they will need to have a very specific hardware report for your system. The computer model alone won't be enough as the chipset and according peripheral chips often are changed even within the same model line due to different CPU models used, bug fixes or also because of redesigns of the hardware to mitigate EOL (end of life) notifications from component manufacturers, or also simply to safe a few cents on a specific chip.
If support hasn't asked you yet for it, I would go into NI Max and generate a detailed system report for your system that hopefully contains all the relevant information about your system hardware and send it to NI with your service request number.
Rolf Kalbermatter  My Blog
Message 35 of 41
(2,161 Views)
Ni support asked me to install by pressing Deselect all button, and then checking NI-DAQmx only, no additional items. Everything installed, WiFi issue is here, but no MAX.EXE installed as you can see in MAX directory content. No chance run NI Max and generate a detailed system report.
Anyway I can provide service tag of my Dell Latitude E6230 (old, heavy, not sexy design, but absolute reliable, durable and fully functional) I offered to lend my laptop to support guys in Europe (no idea in which city they are sitting now as responsibilities and structure are changing each few month recently at NI Europe now) but they dont want it and informed me they will forward all information to US guys.
Petr
Message 36 of 41
(2,156 Views)
Never used the NIPM so far but there should be somewhere the option to also install NI-MAX. It's usually needed anyhow on machines that use DAQmx as you will want to discover NI hardware and optionally pre configure it. Writing DAQ application that can discover all the hardware on their own on a freshly installed system and properly configure it is pretty time consuming and error prone.
After that there should be an option in NI-MAX to generate a full system report for support requests.
The support centers in Europe can not do much with your computer except send it to NI corporate for debugging. Except possibly in India they do not have low level system software development outside of NI corporate. Debugging kernel drivers is however something that can only be done on specially instrumented hardware with access to the full development sources for those drivers.
So your computer would have to be send to NI corporate (or maybe India) completely wiped and reinstalled with a special debug build of Windows and then a software developer could start debugging the issue. This would most likely mean that you will have to live without your computer for many weeks to months. In addition there could be accidents during this that may damage your computer or it may get lost on the way and that is something NI does definitely not want to risk.
Message 37 of 41
(2,138 Views)
bilikp you sir are a genius!
On my problem Dell laptop
were both running and set to "automatic"  I stopped them, and disabled them.  The laptop now reliably reconnects to WiFi after sleep.  I can live with this mod to only enable those two services when working with NI.
Thank you again!
Message 38 of 41
(2,112 Views)
Gentlemen I just found myself that disabling all NI Services helps. Then I reported this fact to NI support. Then they asked me to install strictly DAQmx only, and after several iterations with NI support (each iteration demanded few hours of my time) I isolated problem causing services. That is it. I am glad this information helps to other users.
Anyway I did not test if this solution works if I do install the full NIDAQmx or additional NI SW. No time now to make other tests a have to make my job.
I tried the same on fresh installed Dell Latitude E7470 during this weekend without any issue with WiFi, so this issue seems connected to particular HW.
Conclusion: be carefull when buying new laptop! The time you selected your new laptop without taking care about WiFi functionality after NI SW installation is gone. Ask your PC dealer for NI compliant laptop! 🙂 or ask other NI SW user first if WiFi works on particular laptop, otherwise you will play "a lottery".
Petr
Message 39 of 41
(2,080 Views)
That is definetly ANNOYING.
Just go 2 new Elitebook 840 G5 and G6. The 2 laptops are doing this problem just after instrallation NI suite.
My Lenovo 2 Lenovo T530 had this issue too.
All computers did that only after installation DAQmx.
Message 40 of 41
(1,958 Views)
