Labview wont install anything when I try to install it.
So I had labview before but i had to get rid of it to make space on my computer and i accidently deleted some files in the NI folder before i unistalled it, it didnt unstall it correctly when i went to unistall the program. I have tried everything to get rid of all the NI files on my computer including using CCleaner to try and clean out my registry. I need to reinstall Lab View but i cant since it will run the installer and then not install anything probabaly thinking its already installed.
Message 1 of 19
(5,207 Views)
can you provide the error snapshot?
Thank you & Best regards
syrpimp
“You must continue to gain expertise, but avoid thinking like an expert." -Denis Waitley
Message 2 of 19
(5,188 Views)
Try system restore to time when LV not installled.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 3 of 19
(5,186 Views)
I open the installer and get to the first pciture, then it just jumps straight to saying its done.
Message 4 of 19
(5,177 Views)
try to delete National Instruments Downloads folder on your C Drive, or need try to install Labview 32bit on your computer.
syrpimp
Message 5 of 19
(5,153 Views)
Try doing this: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YGwJCAW&l=en-US
This is supposed to force a reinstall and overwrite what you already have there.
Message 6 of 19
(5,147 Views)
ive deleted every folder on my C: drive that relates to NI products and it still wont install.
Message 7 of 19
(5,098 Views)
I'm sure you've thought of this, but does Windows think the program is installed?  I've had numerous instances (including dealing with one today) of faulty installs, including 2014 refusing to install.  Rather than uninstall or reinstall, what I did (and it worked!) was open Control Panel, go to Programs, find National Instruments, select everything, and say "Repair".  A lot of disk shuffling later, things were better ...
BS
Message 8 of 19
(5,081 Views)
You're probably aware of this already, but Windows is quite fond of hiding things from users.
Do you have explorer set to show hidden files and folders?
There is also National Instuments program data stored in C:\ProgramData\National Instruments that is normally hidden.
Also some in C:\Users\Public\Public Documents\National Instruments
And personal settings stored in C:\Users\%username%\AppData\Local\National Instruments
and C:\Users\%username%\Documents\LabVIEW Data
All of these locations are normally hidden when browsing for files to protect the user from themself.
Troy - CLD "If a hammer is the only tool you have, everything starts to look like a nail." ~ Maslow/Kaplan - Law of the instrument
Message 9 of 19
(5,063 Views)
Thanks to all the advise i managed to get Labview Installed yay!!! but now my problem is whenever i try to run the NI ELVIS instrament launcher for the myDAQ the program starts and then auto quits any help with this new problem guys.
Message 10 of 19
(5,048 Views)
