09-24-2022 02:43 PM
I make two Rs232 in a label as input(Picture 11). The output is show in picture 5.My Labview program runs okay with Rs232 in the Labview 2008.But now I run it in the labview 2012. It has the following problems: I can see the com of RS232 and Com3 and com4 in the Picture1. That means the port of com is ok. But I don't know that why the port in com3 connected is False in Picture 4. Meanwhile the Com 4 is True. So we can see in the picture 8 that Lower is ok that has signal (Com 4).
But there is no response in Upper (Com 3).So my question are:1) Is this the problem of Version of Labview 2012? It cannot make the Two Rs232 into one cable and display in the Labview?
2)How can I make the Com3 and Com 4 work at the same time? I can make sure that my program is ok. So how can I solve the problem of Rs232 communication in Com 3 ?
I want to make sure that : If I want to combine two Rs232 in Labview 2012. That means there are two input. And every Rs232 input has 8 channels input signal. So If I combine two Rs232 (8 channels+8 channels) Fig 11, whether the output can has a 16 channels signal (Fig.5 and 7) in the Labview 2012? I can make sure that my program is ok under Labview 2008 which can get a 16 channels signals.
09-23-2022 11:45 AM
I make two Rs232 in a label as input(Picture 11). The output is show in picture 5.My Labview program runs okay with Rs232 in the Labview 2008.But now I run it in the labview 2012. It has the following problems: I can see the com of RS232 and Com3 and com4 in the Picture1. That means the port of com is ok. But I don't know that why the port in com3 connected is False in Picture 4. Meanwhile the Com 4 is True. So we can see in the picture 8 that Lower is ok that has signal (Com 4). But there is no response in Upper (Com 3).So my question are:1) Is this the problem of Version of Labview 2012? It cannot make the Two Rs232 into one cable and display in the Labview?2)How can I make the Com3 and Com 4 work at the same time? I can make sure that my program is ok. So how can I solve the problem of Rs232 communication in Com 3 ?
09-23-2022 11:57 AM - edited 09-23-2022 11:58 AM
Well the VISA Error message: "The resource is valid, but VISA cannot currently access it" usually means that another program (other than LabVIEW) has the Com port open or you are not properly closing the com port at the end of your LabVIEW program.
Also I don't see any of your Labview code so I will put this here just because I recommend this video every time someone posts a serial communication question...
VIWeek 2020/Proper way to communicate over serial
09-23-2022 12:28 PM
Thanks.
09-23-2022 12:50 PM
@YY2022 wrote:
Thanks.
I don't understand your question. Your pictures are of physical RS-232 connections. Are you having difficulty with 9 pin versus 25 pin RS-232 connections?
Where's the LabVIEW code?
09-23-2022 01:10 PM
Thanks.This is my Labview in Labview 2012. So I just want to know that how to make the Com3 and com4 work at the same time. Because under the Labview 2012, I only get the signal from Com4. Why Com3 not work?
09-24-2022 04:59 PM
09-24-2022 06:17 PM
Thanks. If I want to combine two Rs232 in Labview 2012. That means there are two input. And every Rs232 input has 8 channels input signal. So If I combine two Rs232 (8 channels+8 channels), whether the output can has a 16 channels signal in the Labview 2012?
I can make sure that in the Version of Labview 2008. I can get the 16 channels signal.
So why I can not get 16 channels signal in the Version of Labview 2012?
09-24-2022 07:09 PM
09-25-2022 10:28 AM - edited 09-25-2022 10:36 AM
Hi YY,
When you create a VI to read both serial ports then you can handle the combined 16 "channels" of data…
I guess the LV2012 version does not work because it is different to the LV2008 software.
As you decided to attach only images of frontpanels (mostly) you need to debug on your own!
Keep in mind: we cannot debug/edit/run images with LabVIEW!
On your VI:
Why is there no error handling on all those VISA functions? How do you verify correct execution of all that VISA communication?
Why don't you use DATAFLOW to sequence the VISA functions? Why do you need to use stacked sequences?
