Labview udp client is slower than DAQ
I built an application that reads data from a DAQ and transmits these data to java via udp.
The problem is that transmitted data are less than acquired data. (DAQ works continuously, 1k samples).
Can anyone help me?
(2,957 Views)
Accepted by Skeggy88
If the DAQ assistant is configured for continuous acquisition and does not throw errors (buffer overflow), UDP send is fast enough as well since you do it in the same loop.
I think your problem resides in JAVA and UDP. UDP is a lossy protocol, so it does not care for lost nor unfetched packages. If your JAVA application does not fetch every package in time, it will be overwritten....
Norbert
Norbert
Expert: Geometry
(2,949 Views)
You think that I will bufferize data with java?
Do you know if an example exists?
(2,947 Views)
If there are examples in Java available, they won't be found in a LV forum. I suggest you to search for Java examples using Google (or other search engines).
Norbert
Expert: Geometry
(2,926 Views)
