Reply
Labview to push a button in excel
Highlighted
Dear all,
I have developed a Labview VI but now I need the VI to activate an excel add-in at a certain moment. The add-in allows to start a measurement with a device which I was not able to control by labview (Lightmeter SEKONIC C-7000), and the measurement should start at a well defined moment. So what I need to do is to push a button into excel to start the measurement, while the VI is running.
Is it possible to interact into excel using labview? After the VI has done some initialization, I would need that it goes into excel and push only one button to start the measurement.....
THanks to all for the support....
Message 1 of 14
(1,318 Views)
Its quite possible to Read from/write into excel using LabVEW, what do you mean by push button in excel or do you mean the excel interaction to be happened after push button is being triggered?
Palanivel Thiruvenkadam,
Certified (LabVIEW || TestStand) Developer
Message 2 of 14
(1,312 Views)
Thanks for your quick answer!
In the excel menu, I have an add-on which allows to control the measurement device SEKONIC C-7000.
What I need to do is to periodically push the button "measurement start" - please see the image attached... Is this possible?
Message 3 of 14
(1,301 Views)
can you share the excel file instead of image, so that we can try ourself .
and i have never tried this earlier but i think it sholud be possible by invoking excel application.
Message 4 of 14
(1,274 Views)
The excel file is a generic, empty excel sheet.... It will be then filled up with the measurement results...
Message 5 of 14
(1,271 Views)
The Reason i asked to share your excel is, LabVIEW can able to invoke the inbuilt excel functions, but you have added Measurment start and Measurement abort so need to confirm whether the customized buttons can be accessed via LabVIEW
Message 6 of 14
(1,264 Views)
Here is one generic excel file filled up with some measurement....
However I am afraid that, if you do not have the special add-on for excel to interact with the SEKONIC instrument, you won't see the "measurement start" button
Message 7 of 14
(1,260 Views)
You are correct -- I do not see Measurement Start.
However, you might be able to "have your cake and eat it, too".  Action Buttons in Excel execute a linked Macro when they are pushed.  This suggests that your Workbook (showing the button) has VBA code associated with it that runs a specific named Macro when the button is pushed.  If you examine your Workbook and determine the Macro, you should be able to get LabVIEW to execute it (the easiest way being using the Excel Run Macro function found in the Advanced sub-Palette of the Report Generation Toolkit).
Message 8 of 14
(1,249 Views)
It looks like a cake too difficult to prepare!!!
I am not able to determine the name of the macro associated with the push button. Any suggestion how to do that?
Message 9 of 14
(1,201 Views)
Not experienced with Add-ons in Excel but try this.
In Excel under the Developer tab, enter design mode then look at the properties for the button.
Also under Devloper see if the Add-In functions can expose anything of use.
Edit- Forgot to mention that the code or macro name may be visible via the Visual Basic or Macros selecyions under the Developer tab.
-AK2DM
Message 10 of 14
(1,191 Views)
