Labview showing zero analog voltage values from arduino
Im trying to read values of two EMG sensors from my arduino UNO, on the serial monitor I get correct values of the readings but when i view them on waveform chart in labview, i continuously get zero values.
I also get this error when I press stop:
Error -1073807360 occurred at VISA Clear in test2.vi
Possible reason(s):
VISA: (Hex 0xBFFF0000) Unknown system error (miscellaneous error).
i read the website support details but im still confused, since the VISA resource name ive specified is the arduino COM port. im new to labview so any help will be appreciated
Message 1 of 12
(2,001 Views)
you know you cannot have two programs watch the same COM port at the same time?
Use either LabVIEW or that SerialMonitor, but not both at the same time!
Message 2 of 12
(1,981 Views)
Yes I didn't open both serial monitor and labview at same time but checked the readings on serial monitor first to check if there was an issue in my hardware, and after closing the serial monitor i ran labview. But it still gave me the error
Message 3 of 12
(1,969 Views)
Do you have any explanation why you would wire the iteration terminal to the read count input of VISA read?
Message 4 of 12
(1,947 Views)
I was following this tutorial for the block diagram:
https://m.youtube.com/watch?v=bLUbCD1EcHQ
To be honest, I'm not sure why they did that in the video either
Message 5 of 12
(1,916 Views)
Can you share the code for the Arduino? There are certainly things we can do to simplify this or make it more clear.
Without that information, this is the best cleanup I can do to your code:
Message 6 of 12
(1,893 Views)
your method seems to have worked and im getting proper readings now. however im curious why stopping the simulation and then running it again gives an error and then gives zero values again. its only when i close the VI and disconnect my arduino and open the VI again does the simulation work. i was also wondering if removing the wait of milliseconds in your block diagram will affect the rate at which i get my readings
here's my arduino code:
int END = 5;
int IN7 = A2;
int IN8 = A3;
int emgPin1=A5;
int emgValue1=0;
int emgPin2=A0;
int emgValue2=0;
void setup() {
  Serial.begin(9600);
  pinMode(END, OUTPUT);
  pinMode(IN7, OUTPUT);
  pinMode(IN8, OUTPUT);
void loop() {
  // put your main code here, to run repeatedly:
  long total=0;
  for(int i=0; i<10;i++)
    total+=analogRead(emgPin1);
    delay(2);
  emgValue1=total/10;
  //Serial.println("1st: ");
  delay(2);
  // second sensor
  long total2=0;
    total2+=analogRead(emgPin2);
    delay(2);
  emgValue2=total/10;
  //Serial.println("2nd: ");
  Serial.println(emgValue1);
  Serial.println(emgValue2);
Message 7 of 12
(1,883 Views)
Sounds like you're Aborting the VI with the red circle? That often leaves the com-port open as you haven't closed it properly. As someone said: Using the Abort button to stop a VI is like using a tree to stop your car, it works but it has unexpected consequences.
Qestit Systems
Certified-LabVIEW-Developer
Message 8 of 12
(1,770 Views)
Accepted by topic author Fai
I would make a teak to how you write your values over the port. To make sure you have proper synchronization with the values, combine them into a single write:
  Serial.println(emgValue1 + "," + emgValue2);
Now you will have a single message with both values separated by a comma. No more guessing if you got the order correct. On the LabVIEW side, you only need a single VISA Read. Use Scan From String to parse the data.
Message 9 of 12
(1,753 Views)
I hope you live in a country where "English" regional settings apply.
Otherwise I would prefer to separate the values with a semicolon and set the format string to include "%.;"!
Message 10 of 12
(1,748 Views)
