Labview serial communication with RS 232
hi,
 i am currently working with RS232.My device is working properly but i couldn't able to use because it is showing the following error in my NI MAX and here by i have attached the error page also
Thank you
Message 1 of 8
(3,958 Views)
Make sure you have installed necessary software for the device to get detected in the system.
Message 2 of 8
(3,943 Views)
Install NI-VISA driver if it is not done yet. Could you show what you see under the "Software" entry in MAX (open it)? If VISA is missing, you should install it.
Edit: Your RS232 port a native one in your PC, or you use a RS232-USB adapter? If so, you need to install its device driver also. Be aware that some USB-RS232 do not play nice due to low quality chipset, but usually an FTDI one is a good choice...
Message 3 of 8
(3,934 Views)
ok i will check it out
Message 4 of 8
(3,928 Views)
yes, i am using RS-232 to USB converter but this driver software is working fine, i don,t have an issue. i am facing problem NI VISA software only
Message 5 of 8
(3,926 Views)
Try a repear-install of the NI VISA...
This poster might had similar problem as you: https://forums.ni.com/t5/Instrument-Control-GPIB-Serial/USB-232-2-shows-COM-ports-but-no-VISA-resour...
Message 6 of 8
(3,923 Views)
Thank you after reinstalling the driver its working fine
Message 7 of 8
(3,850 Views)
Then mark the advice as solution 😉
Message 8 of 8
(3,839 Views)
