Labview locks at startup with the network cable attached
I have an embedded application that is running winXP and Labview 7 Express.  I have my VI running from the startup menu as I have no keyboard, mouse or monitor normally attached.  the application uses TPC to commincate over a wireless network.  When I boot the computer with the network hooked up Labview locks up and a few minutes later the computer shuts down.  If I close Labview from Task Manager and restart the app it works fine.  The TPC part of the application is not running until a toggle switch is activated so the TCP part of the program is not active at start up.
Any help would be appreciated.
(2,139 Views)
Is it possible that Labview is trying to run the application before windows has fully come up?
(2,124 Views)
