03-02-2020 07:53 PM
Need some help, there are too many things that I do not know where to start.
I have a multichannel system (meaning one measuring system with one, lets say, a power supply, a switch, many resistors, and one multimeter).
I want to make all the channels sequencial measurements with the switch going by all channels (assume 8).
Instead of having a work area of the 8 channels repeating the same thing, I want to bundle stuff (parameters, some reference measurement for some later calculation), and select them to send to a single channel measuring step.
In the picture I am showing the channels (in this example 8), and for the DUT name, an array with the string names. I could select the name of the sample with the Index Array if I place it on the for loop (same for other 1 dimensional parameters).
But assume now that I want to measure an V-I curve for a reference resistor (to normalize measurements or correct for different switching channels). I will be taking a set of values that I will be using to normalize the data. That is I have a vector of n points length.
How I do the same thing for the nx1 arrays that I want to bundle and then selectc?
Thank you very much,
Gaston
03-02-2020 09:52 PM
Bundle each array into its own cluster. Then Build an Array of those clusters.
03-02-2020 11:44 PM - edited 03-02-2020 11:45 PM
03-03-2020 04:39 PM
1. Integer, if is I64 does not make a difference if is i8;
2. I been using Labview since 4.0 version where everything use to be wired. Then, last 10 years have not used it. So I may not be using all the new stuff available, like the autoindexing;
3. The code is what I show, literally;
4. See picture from Labview help. I got there from some help topics that lead me there.
03-03-2020 05:01 PM
I am willing to help, but there is insufficient information to even try....
03-03-2020 05:47 PM
1. I am a physicist using Labview to capture data, not programming Labview full time, so I do not have gone that deep. The I64 was default, I did not select it nor correct it;
2. Never saw it before. I am aware now;
3. The important details are irrelevant in this case. The arrays today are 2^11 points long (2048 measurement point, until I find the time to trim them), with DBL or EXT data representation.
4. Variants are in the title, because browsing a solution to my problem I stumble on this category that I never used before and the help is useless. I am not looking for a Variant based solution, I just want to do what I shown for the strings (that is, run a bunch i.e. 8, of measurements in sequential fashion, and use a reference to normalize data).
03-03-2020 06:24 PM
Build the ref arrays into a 2D array and autoindex at the loop boundary. You get one 1D array per iteration.
I assume the string array also has 8 elements.
Autoindexing will loop until it runs out of elements, no need to wire N at all.
There is no A/D converter with so many bits that you require EXT. That just slows you down.
