Labview hangs up when accessing RSLinx OPC server if cable is disconnected
I am using Datascoket to connect to RSLinx - OPC server connecting AB
PLCs. It works great. When I am working offline all the datasocket vi
that are trying to communicate to RSLinx OPC server make my Labview
application hang up for approximately 3 minutes. After 3 minutes I do
get an error message and my application handles it properly. It just
doesn't look right for the application to hangup. Do I have an option
to fix this. I chosen a differnt thread (other 2 and standard) for the
subVI fetching values from RSLinx but it doesn't seem to help. The
screen still gets locked up and it doesn't update for at least 2 to 3
minutes. I understand in normal circumstances
I'll not have this
scenario but in the case when I just feel that there should be a
gracefull way to handle a situation like this.
(2,926 Views)
Hi K seeker,
Your best bet would be to check your connection whenever possible for a break. To do this, take your datasocket refnum, and wire it to a property node. You will have the connection status property, which is an cluster. You can then unbundle that cluster and check the Datasocket status, which is an enum. From here, you have the ability to identify when the connection has gone bad. The only drawback is that if you are inside of a Read or Write, then you cannot check it until after that is done. In this case, you would have a timeout set for the read and/or write, with the status checker before you do it. This way, if the connection is bad, you can catch it before you get into a read/write.
Jeremy L.
Jeremy L.
(2,926 Views)
Checking the properties does not work because LV is just talking to RSlinx therefore there are no error codes.  The real problem is that RSlinx hijacks the DS timeout until the requested write is complete.  If the physical connection from RSlinx to the PLC (eg: Serial) is severed, it can hard lock LV while RSlinx attempts to communicate.
(1,427 Views)
