Labview doesn not care about "vi search path "?
We've had some problems with labview taking sub vi's from other library files than wanted. To clean up the mess once and for all I wanted to include the path to the active library files, and remove the <foundvi> from vi search path.
The added path is something like "\\acanova5\common\...", also tried the version "\\192.168.0.50\common\..."
So far so good, but when I open a vi that need sub vis (before located in now deleted lib files) LV don't find them. When then manually point to the lib file and point to the vi it is ok, but why doesn't it work as I expect?
I looked in labview.ini, and my path is the first in "vi search path" list.
Ola
Message 1 of 1
(2,307 Views)
