05-07-2020 10:18 PM
Hello
Thanks for your patience to read this post.
I'm working in a RF cable manufacturer, we have LabVIEW 2017 and Agilent VNA E5071C
I want use LabVIEW 2017 to control Agilent VNA E5071C for RF cable measurement
Already use GPIB connect LabVIEW 2017 and Agilent VNA E5071C , it works
And try to "adjust" a VI which include some Agilent VNA E5071C VI, see details in "Agilent ENA Series Application version6'
want get marker data value, for example S11 value at 200MHz
(you have to first set start/stop frequency and frequency unit in this VI)
but every time i run this VI "Agilent ENA Series Application version6', always get the maker value as start frequency value.
for example, if i set start/stop frequency 100MHz/6000MHz, always get maker value in 100MHz
so my questions are, can i get more examples or how to use E5071C VI? or someone who has this experience can teach me how to use E5071C VI.
just start to learn LabVIEW, thanks a lot.
05-08-2020 02:20 AM
Sorry, seems forget attachedment. here they are
05-08-2020 08:50 AM
Here is the Driver page. Download the drivers and you should have example that you can set up. Look in the LabVIEW examples to see how to use these drivers:
http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=17778
05-08-2020 11:15 PM
Hi Tim
Thanks for response.
as i have showed before, there is limited E 5071C VI example to teach me how to use it.
attached capture you can find there are only 12 E 5071C VI examples
I know there are many E5071C VI. just want to know if there is any material or examples to shows me how to us it. For example, i want get attenuation data @ 200MHz, how to use these VI
05-26-2020 03:27 AM
Hello, have you found any examples? I have also taken over the relevant tasks. I've been looking for a long time. If you have any, can you share it?
你好,请问楼主找到例程了么,我也接手了相关任务,找了很久,想问问你有没有,如果有可以分享么?
05-26-2020 02:39 PM
I see this so often here and I don't understand how anyone can expect to automate a process they can not perform manually. Because frankly when I am automating a task, I use the same basic sequence in my program that I would be doing if I were running it manually.
Also, how will you know if your program is returning correct results if you don't know how check them?
05-07-2022 11:31 AM
I am using a VNA Keysight E5071C , but when run the application created in labview for calibrate the ports, this ports turn off in the VNA, why have this error
05-07-2022 01:08 PM
Something wrong with your LabVIEW code or ask the person who wrote the LabVIEW application.
