05-08-2019 04:53 AM - edited 05-08-2019 04:58 AM
Yes, that could be a solution. Do you have any advice or tips on how to proceed in this case?
Regarding measurement cards, there is also the possibility of using USB-6003, USB-6002 or USB-6009 for me. However, I think it would be the same problem as you said before.
Thank you,
Daniel
05-08-2019 05:51 AM
Hi Dan,
Yes, the same problem as they are basically the same simple DAQ device…
05-08-2019 08:20 AM
@dan23 wrote:
I think ADS1293 is able to communicate by UART as well. Maybe there is some way how to do it.
The data sheet mentions nothing about UART, at least that I could find. I would still go back to the USB-8451 that I linked to before. If I knew Arduinos better, I might go that route as well, but a RS-232 is usually a lot slower than SPI, so you could have data buffer issues there.
