Labview compatibility vis using with NI DAQmx device not working
i use an old application written in Labview 7.1. please see the attachment.
now i use the same software with NI 6221 (DAQmx supported) _so i have installed NI DAQmx compatibility vis.
i use the device as DEV1- default.
i cannot select any channel from the browse option..
please help me
Many thanks in advance
RENN
Kudos always welcome for helpful posts 🙂
(2,800 Views)
Accepted by topic author RENN
If you right click on the control and select 'I/O Name Filtering', does it say DAQ Channel Name or DAQmx? If it says DAQ and not DAQmx, you have a traditional DAQ Channel control and you will not get a list of available channels since you are really using DAQmx. I suspect that is just a limitation of the compatability VIs and you will have to enter the channel list manually until you do a clean break and use the DAQmx functions.
(2,787 Views)
thanks Dennis...as said the control was different.
(2,759 Views)
