It sounds like you have discovered one of the ways to influence the LV
algorithms for data management. For other information, you may want to
look at chapter 27 I believe. It is the Performance chapter. There are
also issues of LTR, application notes, and quite a few emails on
info-labview about this. As for the bug in LV5, it meant that, more
often than necessary, subVIs would make data copies. This was not the
case in earlier versions, nor in LV6i. At least not to my knowledge.
One of the things that one gains when using LV is the freedom from data
allocation and data management. The downside of this is that this
automatic memory management may not be as clever as you are. On the
otherhand, many times there are perfectly good reasons for the data
copies, they just aren't obvious. As for asking NI support for help.
They do a great job, but these things are truly complicated, and this is
sometimes beyond their training. As I said, there is information
available, or if you ask the questions here, I'll do what I can to
answer them.
Greg McKaskle
Hansel wrote:
> On Wed, 11 Oct 2000 13:16:45 +0200, Thomas Ludwig
> wrote:
> >Hansel wrote:
> >> Is there any way to get labview to store this array at a fixed
> >> position in the mem after reading it from disk without generating
> >> copies of this array?
> >No. LabVIEW _should_ do this whenever it is possible. LabVIEW can't do
> >this, when - for example - you modify an array and use the modified as
> >well as the unmodified version of the array. LabVIEW is also forced to
> >copy an array that is passed to a reentrant sub vi. Sometimes (actually
> >quite often!) LabVIEW copies arrays without any reason.
> >LabVIEW 5.0 had a buggy memory management and nearly always made copies.
> >So if you are using 5.0, you should consider an update to 5.1. Don't
> >update to 6i, it is as buggy as 5.0.
> >You might as well ask NI's support, but for me they turned out to be not
> >very helpful (I had an example in 5.0 for solaris that clearly should
> >_not_ copy data passed to a subvi but actually copied data for every
> >subvi call. Although this was a wellknown bug (not to me...) they
> >answered: ' This is the expected behaviour on a sun'.)
> >To sum it up: LabVIEW is bad at handling large amounts of data when your
> >task is so complex that you need subvis - no matter what NI says about it.
> >Thomas
> >PS: I was asking pretty much the same question a few month ago in this
> >group. This is where I learned about the bug in 5.0, not from NI. You
> >might want to look the thread up in deja.
> Thanx for the Info.
> I am using Labview 5.1 and just as you said, labview is making copies
> without reason. Seem's like 5.1 has the same bug as 5.0.
> I've also asked NI for support, but even with the vi-program mailed to
> them they couldn't understand why Labview uses so much memory.
> I've found one solution for reducing the mem-usage as much as
> possible:
> By giving each sub-vi a 'real' call followed by a dummy-call with
> no-data attachted to it, the mem used by this sub-vi (which actally
> stays in mem) is cleared. By doing this I have reduced the maximum
> mem-usage to a foctor 2 of the real data-set, where the actual copying
> takes places at the start, so the program starts slowly but then only
> uses about 1.5 times the array-size.
> I'ts not what I hoped for, but it will have to do. Guess my computer
> could use another 128 MB Ram.
> Hansel
