Labview and arduino mega 2560
Hello everyone!
I am doing a simple task with arduino and labview...
1. Arduino computes something and sent the result to labview by serial port.
2. From labview, I turn on and turn off a relay, using digital pin on arduino.
I already can do this with a Arduino Uno, but when I try to do exactly the same with a Arduino Mega 2560, it doesn't work.
I am runnign exactly the same code on the arduinos, I just check the serial ports and that's all. But, I think it was all.
Do I have to set a configuration on Labview to use a Arduino Mega?
Am I missing something??
I will attach the arduino code and labview file.
Thank you very much 🙂
(2,579 Views)
It seems that labview is set by default to use with arduino uno! So I installed the VI package "Labview interface for arduino".  So, I tryied a simple digital lecture with the following program on labview and I got this error.   (I am using labview 2020).
(2,558 Views)
How can I use labview and an Arduino mega with VISA??
I want to write some code in the arduino and send data by serial port to labview. I understand that I can't do this if i am using a toolkit as LINX or LIFA. What can I implement?
(2,531 Views)
Assuming you already know how to do the Arduino code and have it behave as a serial device...
Check out the serial communication examples that ship with LabVIEW. Also be sure to checkout crossrulz presentation from VIWeek 2020.
The answer to your last question is: whatever you can imagine within the limits of the Arduino hardware. If you are using VISA instead of a prebuilt toolkit you will have to define your own communication scheme. How it works and what it can do will be up to you.
(2,499 Views)
I'm running into the same problem.  I can control an Arduino Uno no problem using Visa, but I'm trying to control a Arduino Mega and no Luck!
If I pull up the Serial Monitor in Arduino Program, I can write commands perfectly.
Did you ever find a solution for the Arduino Mega and Labview?
(337 Views)
