Labview Webdav Get file from Myrio realtime failing, Error 36510
Like the title says, something is going bad somewhere and I'm not sure where. In the attached Image you can see my "code" and what I'm feeding the get function. You can also see in probe 5 the full path to the file I'd like to download, and to my eyes it appears to be perfectly fine, I tried the google this error but to no avail as I seem to be fulfilling the requirement that are stated in the NI page for this error.
In fact, if I copy the string in probe 5 to the explorer I can access the file, so this path seems to be correct, and the destination path is also correct, and there doesn't seem to be an error in the connection before (note probe 3, 7 and 8 ) so I'm lost.
Any help is appreciated.
Message 1 of 1
(2,318 Views)
