Hello Dennis,
I have only tried two vis. Actually they were created on a computer back at the
University
I worked in Wisconsin. The vis were email attached and sent to me here in CA, I have
since
sent them back attached to email and they load fine on the old version.
One difference however is that the program worked with a specific card and dll files
which came
with it. Maybe when labview cannot find the dll file it will refuse to load the
program and they do
not have an error message for that specific problem.
Thanx,
Karl
Dennis Knutson wrote:
> Does this happen with all of your VIs or just one? Do the VIs you're trying
> to convert have a diagram? A diagram is required in order to do the conversion.
> I can load into LabVIEW
5.1 any of my old ones going back to VIs created
> by version 3.1. If you attach one of the VIs (a small one) to a posting,
> maybe someone can determine what's wrong.
> Dennis
> "J. Karl Meinhardt" wrote:
> >Hello Robert,>>Have you loaded LV4.02 .vis into LV5.1.1? The .vi I tried
> to load does have>the .vi extension.>Thanks for the reply.>>Karl>>robert
> laprad wrote:>>> "J. Karl Meinhardt" wrote:>>>> > my V4.02 .vi is not a .vi.
> It seems bizarre that the program will not...>>>> Karl, that's happened
> to me when i forgot to add the '.vi' extension.>> LV doesn't add it automatically,
> if you rename a file, etc.>
