10-14-2010 08:35 AM - edited 10-14-2010 08:35 AM
The Import Shared Library Wizard does not write a wrapper DLL. I don't think you understand the concept of what we're talking about here. A wrapper DLL is a DLL that you write in C. It acts as an intermediary between LabVIEW and the original DLL. For example, for the function you provided earlier, you'd have an equivalent function in the wrapper DLL that instead of having a pointer to GF_SERVER_INFO it would have the individual elements of the structure. The wrapper DLL would handle the packaging of that information into a structure that can then be passed into the original DLL. The wrapper DLL is the one you'd import using the Import Shared Library Wizard.
If you do not know how to write C code then you should find someone who can help you with this.
