I am having an issue when building an application with the actor framework, specifically if "actor.gll" is included in the build the application will never fully close. I disabled everything in my main VI using a diagram disable structure, so that when I build the application it still includes the actor.gll, then I repeated the build with an entirely blank VI in the same gcomp. When actor.gll is included, the application will never close unless I force it closed in the task manager. The blank VI builds without actor.gll and closes without issue.
Does anyone know any way to fix this? Or are there any workarounds for this?
Any help is appreciated.
